How much critical is molecular weight for pressure control valve
I want to know how a PCV (Pressure control valve) works.
Only pressure matters regardless of flow? or the flow as well as gas density also matters?
RE: How much critical is molecular weight for pressure control valve
Generally, if the pressure drop required increases, the port area needed to pass a fixed mass will decrease or at a fixed port opening, an increase in pressure drop will allow more mass to pass through it. However, if the pressure drop through the valve is more than 50% of the inlet pressure, then for a fixed port area, more pressure drop will not allow any more mass to to pass through the valve.
