cutting blade manufacturing process
what is the best manufacturing process and tolerance for garden secateurs cutting blade?and what would be the standard production volume of cutting blade and the material used for cheap cutting blade?
RE: cutting blade manufacturing process
"Cheap" is a relative term that takes quality into account. You can make the blades out of papier-mâché if you want.
Don
Kansas City
