Variable Pressure on Shell element
i'm trying to reproduce an aereodynamics pressure distribution on a Femap model (shell elements) for nastran analysis
I have only the element, no geometry, (i obtain it by my custmer) and i need to generate a 2 dependence variable pressure distribution on shell element......
Infact I have the x,y dependence function of pressure on wing surface(respect to a customized coord sys)
Wen i try to do model-load-elemental-pressure...i cant set the coord sys and the variable andvanced settings......
I usually do that with Patran but now i'm learning to use Femap......
can feemap do that?
Giovanni
can feemap do that?
Giovanni
RE: Variable Pressure on Shell element
There might be a solution if I understand your problem correctly.
If you open the element pressure dialog box ther is a "Specify corners" checkbox near the botton. If you check it the dialog changes from one input value to four values.
Good Luck
Thomas
Now i'm able to reproduce the pressure distribution like i need....
Giovanni
