yield & allow. stress about chinese standard materials
Hi
I'm a new member. Anybody could help me? I need a list of yield stress and allowable stress of chinese standard materials, specifically 16MnR, 20, 20R, Q235-A, Q235-B, 30CrMoA, 35CrMoA, and 30CrMo. I have found a web with the chemical composition of these materials, http://www.chinabeitai.com/doce/cp02-2.htm but not the stress values.
Thank you in advance
Sergio Romon
Sergio Romon
RE: yield & allow. stress about chinese standard materials
*The A or B suffix may indicate a specific heat treatment, other processing or grade. You probably need the applicable Chinese GB standard (which can be purchased from standards suppliers).
Still trying to help you stop corrosion.
formerly Trent Tube, now Plymouth Tube
eblessman@plymouth.com
or edstainless@earthlink.net
I know that the mechanical properties of any material depends on the differents heat treatments (and chemical composition too). About the Chinese GB Standard, I haven't found a copy in english language. I think it is only in chinese language.
EdStainless, these materials are for a chinese code application, not ASME code application.
In any case, thank you both for your help.
P.D.: I'm soory for my awful english
