Steel joist bridging through masonry walls
When joists are parallel to masonry partitions should the bridging start and stop at the wall? Can it punch throught the wall and be grouted in place? what are the adverse effects of this? would a clip angle detail at the wall allowing vert. deflection be required? If less than 3/4" of max. vert. deflection in the joists would be anticipated, would there be much of a point in allowing for the deflection?
Can anyone comment on this.
PG
PG
RE: Steel joist bridging through masonry walls
DaveAtkins
But you can use horizontal bridging throughout the joists and then use X bridging in the second joist space from the wall and NO briding on the wall-side of the last joist.
OR - you can use horizontal briding throughout and simply run the briding horizontally into the wall and attached with a small clip angle and sleeve anchor. This is what you usually see. I've never seen bridging run through a wall unless the wall was constructed after the joists were all up. And even then I would think that the bridging would be terminated at the wall face.
Use a clip angle attached to the masonry with sleeve anchors and attach the bridging to the clip angle.
Mike McCann
McCann Engineering
