VFD heat dissippation
I am working with VFD. The heat loss from VFD is 200KW.plus other heat loss. The total heat loss is about 230Kw. Does it mean the HVAC has to sized to be larger than 230Kw?
RE: VFD heat dissippation
I would think you save a bundle by just turning the air over instead of mechanically moving the heat. Yuck.
Keith Cress
8% losses in the VFD alone? That seems a poor dive efficiency to me. In fact, even if it included the motor losses I think it would be a lot. Is that the data from the manufacturer? Is the drive system continuously running?
I am having a problem picturing a truckload of transformers gathered around some relatively small VFD.
Keith Cress
The one's I've seen use one special multi-winding transformer with multiple secondary windings.
Keith Cress
Phase shifting transformer paper
And then to see how this translates to the real world of MV drives, go to page 9 of this brochure.
Robicon perfect harmony drive brochure
PS: They are not exactly "little" drives we are talking about here.
Keith Cress
