Solidworks SwCreateMST.exe
I am using SwCreateMST.exe to create a transform file that I then deliver via Active Directory. After I create the transform and use MSIEXEC to test the MST file that was just created the Add-In's like toolbox are not available. If I do not use the MST file and install from the admin image I do get the add-in's. Any ideas. This is my command line to create the MST file.
SwCreateMST.exe English_i386_SolidWorks.Msi SOLIDWORKSSERIALNUMBER="0010003051927070" SERVERLIST=25734@mks00w0 OFFICEOPTION=1 UNITSELECTION=2 DIMENSIONINGSTANDARDSELECTION=1 INSTALLWDS=0 ENABLEPERFORMANCE=0 ADDLOCAL=English,SolidWorksAnimator,SolidWorksTaskScheduler,FeatureWorks,InstantWebsite,PhotoWorksRender,SolidWorksToolbox,SolidWorksUtilities,RealViewGraphicsdisplay
