Flowline Corrosion protection
Need some information about best method/product to protect against corrosion 8" Carbon Steel flowline after hydrotest, line is planned be water filled for and one/two years another part of project be completed.
RE: Flowline Corrosion protection
Will you remove the water?  If not, use a corrosion inhibitor and leave them full.  I've left pipelines stand for 18 months without any trouble.
http://virtualpipeline.spaces.msn.com
Thanks for your fast answer, one more question can you suggest any corrosion inhibitor.
Depending on where you are, you may also need a biocide and an oxygen scavenger.  Talk with the chemical companies and let them know your hydrotest water source and quality specification.
Steve Jones
http://www.pdo.co.om/pdo/
What is going to be in the pipeline later?  If you will have a rust in the product quality specification of any kind, clean and dry the line and cap with N2.
If its a flowline, I was thinking there's gonna' be a lot of well materials, sand, bit parts, mud, oil, H2S, CO2, wax, hydrates, probably N2, and hopefully a little gas and/or oil, so any special cleaning (other than removing construction junk) now might not be needed at all.
Guys,
I received the information requested by REP, the product is BACTIREP 1418 it's a biocide and treatment with 2000 ppm,  protection is for one year.
