Busted steam check valve of pressur
Busted steam check valve of pressure boiler drum....
Our company has 4 coal fired boiler and two fuel fired boiler. We are required to maintain 1 MPa to maintain the production operate in a good condition.we operate 2 boler at a time to avail these requirement.the connection of the two boiler are in a parallel manner.
at time that we operate the bunker and the other boiler the cheked valve head of bunker side was explode...
the question is, what is the most probable cause of explosion.Is the connection of the boilers are critical if they run not simulteneiously? What are the tips to avoid this kind of sequeces if there is ?Is pressure hammer exist, that is why the pressure at the bunker exceed to the check valve design pressure limit?
thanks....ROCULLO123
RE: Busted steam check valve of pressur
