how to remove oil from fasteners without using water
we are a job shop, one customer requires us not to use water (cold or hot, with anti-rust agent or not) to clean parts, because the metal parts is very sensative to get rust. the parts after process normally covered with machine oil. is there any way or equipment to remove oil. someone suggest a powerful blower might do the work. any one has such experience?
thanks,
thanks,
RE: how to remove oil from fasteners without using water
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
h
Ted
good luck!
-pmover
Just saw this on The History Channel: Clean the parts with a high velocity stream of dry ice particles. Takes mold off books without wetting the paper!
Mike Halloran
Pembroke Pines, FL, USA
