ASME Approved Abbreviations
Here is a helpful link for ASME Approved Abbreviations.
http://www.electromark.com/help/Valve/asme_approved_abbreviations.asp
Heckler   americanflag
Sr. Mechanical Engineer
SWx 2007 SP 4.0 & Pro/E 2001
      o
  _`\(,_
(_)/ (_)
This post contains no political overtones or undertones for that matter and in no way represents the poster's political agenda.
RE: ASME Approved Abbreviations
Are you sure they are ASME approved?
I just checked several of them and they aren't in ASME Y14.38-1999 Abbreviations And Acronyms or are in with different definitions.
For instance BATT is batten in Y14.38 while your link says it's battery.  In 14.38 battery is BTRY.
I've found most online lists of acryonyms don't follow 14.38 very closely.
If you can find an online copy of MIL-STD 12 that may be better but there are differences between it and 14.38.
KENAT, probably the least qualified checker you'll ever meet...
You're right!  I just checked a couple against MIL-STD-12....what was I thinking posting an unapproved website hammer  I guess I was trying to harvest some stars.
      o
  _`\(,_
(_)/ (_)
Hey, I didn't red flag itwinky smile
It's frustrating though when something looks good, says it's good but turns out not to be.
While I try and remember that anything on the web is guilty until proven innocent, I probably fail sometimes.
I'll give you both stars for effort.
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
