I need to add some tapped holes to
I need to add some tapped holes to the hole wizard that are presently there, like a 1-5/16-12 tap for a Swagelok.
How do I go about this?
Timelord
Timelord
RE: I need to add some tapped holes to
Exactly what I was looking for. Funny this FAQ didn't show up whren I searched on the term "hole wizard".
Timelord
Timelord
There are two tabs under "your new standard/Hole Wizard Holes/Tapped Holes". One is "Bottoming Tapped Hole" and the other is "Tapped Hole" I always ensure I put the data in both. Never had a problem..
If you still have further issues, I could outline step by step how we have done it, I you'd like.
Thanks for the reply. I went back and made sure that I filled out both the bottoming and regular tapped holes and that seems to have worked except the hole callout in a drawing only calls out the tapped hole diameter, no thread data. Am I still missing something?
Timelord
When opened, along the left you will see the callout information for the holewizard standards: "[ANSI INCH]"
You need to copy all the information from the standard you derived your new standard in holewizard from, then reinsert the copied text at the end of this file. Rename the text you just placed to the name you originaly choose for your holewizard copied standard. IE; "[copied standard]"
Then just click save. Restart SW.
This should take care of your callout issue..
Thanks! A star for you.
Timelord
