Select by attributes not in ACAD? :(
Been a Microstation user for the past 4 years. Now ACAD for 6 months.
In microstation you can select layers (levels) by attributes. Basically, isolating and selecting for quick editing.
The problem is in ACAD I'm trying to make a large selection, then change the color properties back to "by layer". Unfortunately the only options I get are (Layer, Linetype, and Lineweight), not color. Boo.
It would be easier there were any layer structure to this dwg, but it came from another firm, so isloating layers individually will take some time.
RE: Select by attributes not in ACAD? :(
I was a Terramodel user before and Terramodel lets you select all object on one layer which I really miss so I feel your pain.
____________________
Acad2006, Terramodel
