Flat Pattern in Inventor 2008
I was wondering is there any way to lock in a size of a flat pattern in a .dwg. The problem im having is when there is more than one size in a table for a flat pattern. The blank can only be inserted under a a active member not a specific size.
RE: Flat Pattern in Inventor 2008
For Inventor use either the Autodesk Inventor forums or Sean Dotsons mCADForums.com .
David
