115Volt D.C Bodine Motor help
I am sorry for asking a stupid question but I am stuck, and I need some help.
I have a Bodine D.C motor that I would like to use for making a Speed controlled "Bead Roller". There is four Wires that come out of the motor (2) blue and (2) Black wires am I correct in assuming that one set is for the forward control and the other set is for the reverse control?.
This Bodine motor is a 115 V.D.C. speed reducer motor. The motor has a R.P.M. of 1725 and the reducer output rating of it is 17.0 inch lbs. and the RPM is 173 which gives me a ratio of 10 : 1
I would like to use this with a foot control for speed and also forward and reverse.Am I barking up the wrong tree to use this motor and if not how do I figure out what wires go where?
Thank you in advance for any help that you can give,
Techman10
Techman10
RE: 115Volt D.C Bodine Motor help
You need a Bodine catalog.
Mike Halloran
Pembroke Pines, FL, USA
Sometimes I wake up Grumpy.
Other times I just let her sleep!
http://www.minarik.com/
Thank youall for the help thus far.
Techman10
Try and leave whoever or wherever you go just a little better. RESPECT! Can take you a long way in life.
See if you can find it here:
http://www.bodine-electric.com/Asp/ProductMenu.asp
Mike Halloran
