L-shaped pressure vessel
Hi there,
Is there any ASME code or other standard out there that talks about L-shaped pressure vessels? I know that Section VIII Div 1 Appendix 13 covers non-circular vessels, but none of the geometry matches to what I am analyzing, which is an L-shaped hydraulic cart that sits on a platform. Any comments/suggestions are greatly appreciated.
Thanks in advance.
Thanks in advance.
RE: L-shaped pressure vessel
jt
Joe Tank
Does your vessel have a name plate? Does it qualify to be a pressure vessel at all? Is there any identification for the design code used in the design / fabrication of your vessel?
A specialised pressurized hydraulic reservor can be employed only if it is provided with a valid nameplate, in accordance with one of the world wide approved design codes.
Can you please clarify this issues for us?
cheers,
gr2vessels
I believe you are correct with regard to the new Div. 2 (2007) Part 5 analysis, and probably with the 100% RT issue. Is there a problem with the RT?
gr2vessels provided some good questions you should get some answers to. You may have an argument that this container is "an integral part or component" as described in Div. 1 U-1(c)(2)(c). Consult with the jurisdiction where this will be installed if you are not sure whether the container needs a stamp. Either way, don't forget to consider fatigue if this container is going to see pressure cycles. The stresses at the corners may work for a few cycles but kill the fatigue design.
jt
