Spiral Beval Gear with 4:1 ratio ?
Is there a manufacture that produces spiral bevel gears with a ratio of 4:1 or larger?
The diametral pitch will be 12 or 10 and it will be preferred if they are Aerospace quality.
Dave
RE: Spiral Beval Gear with 4:1 ratio ?
You can probably find a high quality (automotive) hypoid R&P close to that, but it has an offset axis.
As for AGMA 12 or better (aerospace quality) spiral bevel sets, I don't think you'll find anything "off the shelf". But there are literally dozens of capable gear manufacturers that can produce high-quality, case hardened & ground spiral bevels to your specifications.  Anyone with a Gleason grinder can do it.
You also might try to find a replacement gear set from a light helicopter gearbox.  Most helicopter transmissions use spiral bevels.
Or if you've got some budget, I can recommend the name of a very good helicopter transmission guy that could design those gears for you.
Good luck.
tbuelna
Thanks for the info.
Yes there is,
ATA gears in Finland up to 7:1 when i last needed them
Greetz,
Martin
Unigraphics NX4,NX3,NX2,R17
Inventor 10,9,8,7
Solid Edge 10,9,8
Solid Works 2000,98
Mechanical Desktop 4,3
Autocad 2004DX,2000,R14, R12
Teamcenter 9
