New NX4 Sheet Metal Module and Beads aroung a bend
Is it possible to create a bead that passes thru a bend and is on both flanegs and be able to unfold it as either as flattened solid or a wireframe flat pattern? Ans have it show up correctly on the flat? The bead would eb around the outside of the apart and act as a stiffening object.
So far I have had to modeli with conventional featyres and then syppress it before unfolding or flattening a wireframe. But then it does not show up in the flat.
RE: New NX4 Sheet Metal Module and Beads aroung a bend
John R. Baker, P.E.
Product 'Evangelist'
NX Product Line
SIEMENS PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
