Displaying Sheetmetal Bend Allowance Lines
Using Solidworks 2007. The Bend Allowance lines don't display. Is there a setting to get them to display?
RE: Displaying Sheetmetal Bend Allowance Lines
Not exactly sure what you mean my Bend allowance lines won't display... but If your talking about where the bends is at then look under the Flat-Pattern feature. RMB "Flat Pattern" and edit the feature. There you can select what to see at the bend.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
Have they displayed for you before and have now stopped?
If so, have you changed anything recently?
What video card and driver are you using?
cheers
