How to create a pattern along a circular protrusion
Is there a way to create a pattern along the face of a circular protrusion other than sketching it first and using the curve feature that copies it onto the face and then using the normal cutout feature? The problem with that is the further the sketch is from the center the more the pattern changes on the face of the protrusion.
Thank you
Thank you
RE: How to create a pattern along a circular protrusion
If the pattern is copying the same cutout you can use the pattern along curve feature. First create sketches that define the first cutout and the curve that defines the path or paths on the surface of the protrusion. Then use pattern along curve.
Jef
Thank you
bc
