Floating Suction System
Can someone out there please help with me these
1) Data Sheet (template) for Floating Suction System
2) Specification for Floating Suction System
RE: Floating Suction System
APPI44, this site can be of some help for you www.emcowheaton.de. Click on "Products" and after fill in some data (language, contry, etc.) you will find Storage Tank Equipment.
Good luck !
I purchased about a dozen tanks recently that had many floating suctions. All I specified was the minimum float height, maximum float height, outlet nozzle location, pipe diameter and material. For an existing tank, you would have to specify tank diameter too. Send this info to a tank vendor and see what they come back with.
