DGA Backfill as 'brace'
When constructing cofferdams for 'small' bridge footings we often backfill the void between the concrete footing and temporary steel sheeting with dense graded aggregate (DGA). This allows us to remove the lower tier waler and cross braces. In essence, it provides a continuous brace. When the space between the footing and steel sheeting is relatively narrow with respect to footing thickness, this works well. In some cases we would just extend the footing width and pour tight against the sheets and use a bond breaker if approved by the engineer. How would you evealuate a situation, i.e., determine the adequacy of the DGA to resist loads where the space is wider, say maybe 6 to 8' with a 3' thick footing? Any input would be appreciated.
RE: DGA Backfill as 'brace'
