Any Reviews on Reliability Direct Motor tester?
I am familiar with Pdma Corp MCE tester, now my company wishes to purchase a Reliability Direct All Test Pro.  It is much less expensive than the MCE.  Does anyone know if it is any good?  We test polyphase motors up to several thousand HP.  It appears that this tester is only good for small HVAC applications.  Any thoughts?
RE: Any Reviews on Reliability Direct Motor tester?
The AllTest Pro 31 is not limited by the size of the motor.
It incorporates tests for faults to ground, internal faults such as turn-to-turn and coil-to-coil and phase balance. Electric interference from residual or stray currents from test-object or surrounding power sources is measured by an included EMI test.
Testing frequencies are selected from a range of 25 – 800 HZ, which enables the instrument to test fractional as well as large AC/DC motors, generators and transformers, multi or single phase.
In addition, the instrument features a patented rotor test, which quickly finds broken rotor bars and casting voids.
You may download a data sheet here:http://www.reliabilitydirect.com/motormonitor/pdf/AT31.pdf
