Exploded Views
Exploded Views
Exploded Views
Running Solidworks sp3.1
All i want to do is increase the time of the exploded view to more than eight seconds so that the animation performs in a much slower time so I can actually see each of the parts explode! Many thanks.
RE: Exploded Views
You can run/create the explode through Animator if you have that add-in.
Dan
www.eltronresearch.com
RE: Exploded Views
If you're selecting "animate explode", there is a half-speed button on the animation toolbar that pops up. Beyond that, you'd need to edit in animator to be able to expand time.
Jeff Mirisola, CSWP
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
RE: Exploded Views
If you are making an actual animation. Drag the key out in the time line and that will increase time. Other wise you can run it at half the speed as suggested above.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
