Low pressure ratio, high flow compressor (Blower?)
I am new to the compressor world (and this list) and think I may be looking for something that falls in between many of the standard designs out there.  I need to compress helium from 1 atm to 1.1 atm at a flow rate of 300 l/m.  The gas starts at room temperature and the pressure ratio might need to go up or down a bit.  The system needs to be clean and sealed, and I would like something that has a high thermodynamic efficiency.  At first I thought a centrifugal blower would be the right design, but they tend to move ten times as much gas for the smallest models.  Any suggestions would be appreciated.
    Thanks in advance
RE: Low pressure ratio, high flow compressor (Blower?)
Look at a positive displacement straight blower, commonly called a Roots style.
at bthose ratios and small voume, don't worry about efficiency, put you money in a unit that has no seals.  A hemetically seal air conditioner type compressor would work.
