macro for screen capture
Hi everybody.
I am trying to build an animation showing how the change of a dimensional parameter affects my model.
Since I can't find a better way to do that, I imagined a way by creating a macro that would change that parameter in small steps and record each one to a .jpg or .tiff file, but I don't know how to include the order to save the screen to a file, in the macro.
No need to say that this is my first experience with macros and VB.
Thanks to all answers and suggestions.
Roberto
RE: macro for screen capture
You can start record a video file (choosing a convenient codec) and after that launch your macro who will change your parameter.
Try to record first a simple macro, changing what parameter you want in your CATPart, maybe it will work.
Fernando
It didn't work for me. CATIA always gives me wireframe instead of shaded solid.
Forever Young
Hi all and thanks for you answers.
I figured out a workaround using ferdo's suggestion and it worked!
I made a macro asigning different values to my parameters  with execution-stop (F9) at every update, then started recording my viewport and, step by step run the macro, getting 2-3 frames per step so after some clicks I got my animation.
