MP35N Sring Design
MP35N Sring Design
I am new to forum so thanks in advance for any help.
I need to put together a consulting team quickly for a very specific spring design for an orthopaedic implant. Can you guys help me find the right people?
The design requirements are established. My envelope is 10mm OD X 30mm long (free length). The solid height must be 24mm or less. The working height must be 26mm with a force of 40 lbs (k=254 lbs/in). My material choices are limited because this is a long term implant. I can use 316L stainless, titanium (several alloys), MP35N, or Elgiloy.
My best spring to date is a spring made from .087” dia MP35N wire (cold-worked 45%, Aged to 255ksi). After cold winding, the spring is shot peened. Note, the spring index for this is low, 3.5, and I know this is not ideal but it is the only way I can seem to get the proper spring rate.
This spring would be perfect except the fatigue life is only about 1MM cycles and I need 10MM cycles.
I am confident that with the right wire, wire treatment, coiling and post treatments I can get the increases in Fatigue life I need. I just don’t have the time to figure it out so I am willing to hire outside help to expedite the process. Any ideas who I should contact?
Michael
Michael
RE: MP35N Sring Design
http://israelkk.googlepages.com/home
They are located in New Jersey and often work with titanium springs. You can contact them at 908.788.5800 If you ask for John King, I believe he is still the engineering manager, he should be able to help you out.
