Allowable Stress on Lifting Lugs
I am conducting an FEA of a lifting lug on a Div 1 vessel. I am looking at the stresses caused by altering the lift angle from 0 degrees (vertical) to 45 degrees off the vertical.
The lugs are attached on the 2:1 elliptical head with a repad.
Am I correct in applying UG-23 (d) Sps = 3S as the allowable stress at the weld locations (Lug-to-repad) and (repad-to-shell)?
RE: Allowable Stress on Lifting Lugs
There's a lot more to it than just comparing a peak stress from an FEA to an allowable...
jt
