FRP hoop stress
FRP hoop stress
FRP hoop stress
What is used for the allowable hoop stress in a filament wound vertical FRP tank?
RE: FRP hoop stress
Read RTP-1.   It is very complicated as it depends on your laminate structure, fiber orientation, etc.  RTP-1, Appendix M will tell you everything you need.  Sorry I can't comment more as it has been more than 13 years since I last did an RTP-1 calculations.  Best is just let the fabricator do the design and quote it for you.  That's basically what everybody does.
RE: FRP hoop stress
ASTM D-3299 and ASTM D-4097 give a very limited allowable stresses for atmospheric tanks...
RE: FRP hoop stress
Try ASME X, BS4994, BS 7159 or ISO 14692 as a start point.
GRP is a generic term for a composite structure. there are no single values. It is a complex calculation using emperical data related to the composite structural design.
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
www.waterhammer.bigblog.com.au
RE: FRP hoop stress
wfn217 (Chemical) & Team Members:
Additional Reference:
User’s Guide to ASME Standards for Fiberglass Tanks and Vessel MTI Publication No. 50. RTP-1 and ASME Section X.
Leonard Stephen Thill
