Need suggestions for electrical motor selection
I'm building a device which includes a flywheel which is connected to a drive shaft with a lobe on it (just to keep the description simple). The lobe, at BDC, will be creating compression pressure on a plunging pin in a die which needs to be at least 1/2 ton, for every stroke of the lobe.
I have dimension constraints which are about 10"W x 10"D x 20"H, and unfortunately the stored energy in a fast moving flywheel isn't applicable (thanks again Don). Therefore I need a slow moving, high torque electric motor not more than 5" H x 10"W to fit in the bottom compartment of the unit.
I haven't calculated the needed torque just yet, but I would appreciate any suggestions of suppliers that have motors for what I need. If I know of suppliers that have motors that provide the maximum torque available, I'll know the limits and can work backwards from that known maximum.
Many thanks beforehand!
Bret
RE: Need suggestions for electrical motor selection
I forgot to mention the motor must run on 120v A/C household current.
Sounds like what you need is a motor with a gearbox. They're readily available. Where are you located? There's little point in me posting a list of European suppliers in you are in South America.
Sometimes I wake up Grumpy.
Other times I just let her sleep!
I agree with ScottyUK, AC motor and a gear box.  A 56C frame motor with a right angle worm gearbox may fit.
Thanks Scotty and sreid. I'm in Miami, Florida USA.
I got a piece of info. from a web search that indicates I may be needing a motor with 20lbs or torque, but I'm not counting on that spec. yet. It would still be good to know what the max possible is and a good supplier.
You could start with Leeson.
http://www.leeson.com/
