Material Not Listed In Table Y-1??????
I'm currently designing a Shell & Tube heat exchanger with SB-111 C68700 Tubes. In Section II-D, Table 1B, (pg. 182) the material is listed as being allowable for Section VIII, Div. 1 units up to a design temperature of 450°F. However, the material is not listed in Table Y-1 & Compress asignes the material a Yield Stress of 0 psi.
If Table 1B lists the material as usable for my design, why is it not listed in Y-1? Secondly, can I still use this material for my Section VIII, Div. 1 exchanger?
RE: Material Not Listed In Table Y-1??????
ASME provides the material property tables for the convenience of vessel designers and consistency of designs. Also, certain Code rules are based on assumed values for modulus of elasticity, etc. But not all properties are available for all materials at all temperatures. If the information is not available in Section II Part D then other sources should be consulted, including the steel producers.
COMPRESS provides options to extract material properties from ASME, TEMA, or as user-defined. The user-defined option should be used if the information is not available in ASME Code or TEMA Standard.
Tom Barsh
Codeware Technical Support
