Flexible sub-assembly and Solidworks 2008
Hi all, I don't know if it's me but I can't find the flexible option for sub-assembly.
Do you have the same problem?
thanks
maxb
RE: Flexible sub-assembly and Solidworks 2008
When you RMB on the sub-assembly and select properties, the option isn't there?
Jeff Mirisola, CSWP
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Hi Jeff, yes the option is supposed to be there like Solidworks 2007, but in 2008 when you right click on part or sub-assembly you don't have the properties "button".
thanks
maxb
Do you still have the Customize button? If so it may just need to be selected from that list.
cheers
That's right...it's there but not where it was. In the "head's up" box, there's an icon that looks like a hand pointing at a piece of paper, that's your component properties button. And, I just checked, solve as flexible is still there.
Jeff Mirisola, CSWP
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
I forgot to mention when you RMB on the sub-assembly, in the head's up box...yada, yada, yada.
Jeff Mirisola, CSWP
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Hi all, Jeff found the properties button
thank you to all for fast reply.
maxb
