Capability of 80C31 MIcrocontroller
recently i'm doing a project on microcontroller...anyone with information on the range of frequency that a 80C31 microcontroller can count up to? i need to know the lowest frequency that the 80C31 can detect....and to write a source code to detect the input frequency? anyone can help?
RE: Capability of 80C31 MIcrocontroller
<nbucska@pcperipherals.com>
tq,
bok
thank you for your prompt reply...the frequency i need to detect is very low...around 1-4HZ... can a micrcontroller capable of detecting it? i do some testing ..and it seem to be cannot.... so do you know the limitation of it? i mean the maximum and minimum it can goes...i'm using a 12 Mhz crystal..thanks for your help..
firstly, u should have a ADC to convert ur analogue freq. to digital for 8031 uP to trace the point, after that is u to write a softcode to trace the time for waveform point from 1 max point (peak) to the other max point(peak) ==peak to peak & use delay subrountie to calculate/compare the period for the time peak-peak.. then f= 1/T
I was involved with the 80c31chip during the eighties when I worked for Racal, I remember a bit about them and I believe that they can work from a couple of megs right down to DC, ie stopped clock, then proceed again when the clock starts up.
Hope this helps.
Has anyone got access to the programming language for this chip, as I have a couple of dozen of brand new ones in my garage with no way of using them.
Thanks.
