Looking for extra-low-profile retrofit valve actuator
I'm looking for actuators I can retrofit onto existing standard sweated 1" manual ball valves for a high-rise building automation project. The existing clearances are tight. Does anyone make a standard actuator that is barely higher than a typical bronze sweated ball valve's existing handle?
If I can't find actuators, I will either have to unsweat the valves and rotate them to a new orientation, or simply put in new valves.
All help is greatly appreciated!
RE: Looking for extra-low-profile retrofit valve actuator
rmw
