Placing text via script?
I would like to know if it's possible to add text to a drawing at a given point location?  I have some information that goes on a drawing - same place everytime, but I want to add a user interface that is filled out when the title block is inserted.
I tried recording a macro which had me selecting the point at which to add the text, but it was to no avail.  There was nothing the resultant macro.
Thank you.
Catia Design|Catia Design News|Catia V5 blog
RE: Placing text via script?
  Set Text = DrwTexts.Add("Text", x, y)
  CATFormatTBText "TitleBlock_Text_Label_PartNumber", catTopLeft, 2
Earlier example was modified from the CATScript Titleblock code supplied with CATIA which placed the desired text in the x,y location and applied the formating via the CATFormatTBText function.
'This example retrieves in CharString the character string of the MyText drawing text.
CharString = MyText.Text 'retrieves
MyText.Text = CharString 'sets
'This example retrieves the x coordinate of the text MyText drawing text.
 CurrentX = MyText.X 'retrieves
'This example sets the y coordinate of the text MyText drawing text to 5 inches. You need first to convert the 5 inches into meters.
 NewYCoordinate = 5 * 25.4 / 1000
 MyText.Y = NewYCoordinate
I noticed that it was taken from that script.  Originally, I tried to modify the same script to work, but I can't seem to quite get it.
I need to get the script to plug in user defined text, to the same spot on the sheet every time.  It needs to be placed in the sheet view. (so the script has to automatically switch the view)  I'm not really sure how to define the "DrwTexts" variable.
Here is what I have so far:
Sub CATMain()
Set DrwTexts = Catia.ActiveDocument.Sheets.ActiveSheet.Views.ActiveView.Texts
  Some Text = InputBox("Review has been completed by:", "Reviewer's Name", "Reviewer")
  Set Designer = DrwTexts.Add("Designer",20 ,20)
End Sub
Set DrwTexts is not correct, I am sure.  I don't know exactly how to set the sheet, rather than current view.  Do I need to just remove the "Views.Activeview" portion of that line?
Also, while there is no error, there is no output generated by this code.
Thanks for your help.
Option Explicit
Public ActiveDoc      As Document
Public DrwDocument    As DrawingDocument
Public DrwSelect      As Selection
Public DrwSheets      As DrawingSheets
Public DrwSheet       As DrawingSheet
Public DrwView        As DrawingView
Public DrwTexts       As DrawingTexts
Public Text           As DrawingText
Public Designer       As String
Sub CATMain()
 Set ActiveDoc = CATIA.ActiveDocument
  Select Case TypeName(ActiveDoc)
    Case "DrawingDocument"
      Set DrwDocument = CATIA.ActiveDocument
      Set DrwSheets = DrwDocument.Sheets
      Set DrwSelect = DrwDocument.Selection
      Set DrwSheet = DrwSheets.ActiveSheet
      Set DrwView = DrwSheet.Views.Item(2)
        DrwView.Activate 'sets and activates background
      Set DrwTexts = DrwView.Texts
    Case "PartDocument"
    MsgBox "Please Activate a CATDrawing"
    Case "ProductDocument"
  End Select
Designer = InputBox("Review has been completed by:", "Reviewer's Name", "Reviewer")
Set Text = DrwTexts.Add(Designer, 20, 20)
End Sub
OK, 2 more questions -
1)Set DrwView = DrwSheet.Views.Item(2) - what if there are no views yet?
2)How do I set the text size, color, and position?
Thank you.
  Text.Name = "Designer"
  Text.anchorPosition = catMiddleCenter
  Text.SetFontName 0, 0, "Monospace821 BT"
  Text.SetFontSize 0, 0, 3.5  '3.5=fontSize
  DrwSelect.Add Text
  DrwSelect.VisProperties.SetRealColor 0, 0, 253, 0
  DrwSelect.Clear
  Set DrwView = DrwSheet.Views.Item(1) 'Create Drawing generates 2 views by default`
  DrwView.Activate
I'm a bit confused, here...  'DrwView.Activate' is no longer activating the background view.  Also, whether this page is new, or has 100 views on it, this text *should* always goes to current sheet background, and I know that's not the way that I've set it up.
What am I doing wrong?  Here is my code:
Sub CATMain()
    Set Selection   = DrwDocument.Selection
    Set DrwView     = DrwSheet.Views.ActiveView
    DrwView.Activate
    Designer = InputBox("This review has been done by:", "Designer's Name", "Designer's name")
    Set Designer = DrwTexts.Add(Designer,(13.5*25.4) ,(1.25*25.4))
        Designer.anchorPosition = catMiddleLeft
        Designer.SetFontName 0, 0, "Monospace821 BT"
        Designer.SetFontSize 0, ,7       '7=fontSize
End Sub
Unless I am wrong the Views collection have(by default with a new drawing) 2 items, the background and the main view. Any other view created will be listed after in the collection.
Eric N.
Set DrwView = DrwSheet.Views.Item(1) 'sheet.1
Set DrwView = DrwSheet.Views.Item(2) 'background view
Paste the '28 Sep 07 7:13' post and insert the '28 Sep 07 8:37' after the 'Set Text = DrwTexts.Add(Designer, 20, 20)' into a catvba file and it should work.
