Animating complex shapes
I don't know if this is the right forum for this.
I would like to animate some mode shapes, at the moment I have  written my program so that it uses cos(real part of mode shape) + sin(imaginary part of the mode shape). This indeed produces a shape which seems correct, but when I compare my complex mode shapes to those in a commercial modal analysis program(mescope) the shape at 0 degrees( when  the shape should be entirely imaginary?) looks slightly different than mine, although using the same data.
Many thanks in advance
Harry
RE: Animating complex shapes
Hmmm what software are you using?
Tobalcane
"If you avoid failure, you also avoid success."
I've written my own software. I'm comparing it against Vibrant technology's Mescope.
Please ignore the formula in the first post, thats not what I've written, I didn`t have the code in front of me when I wrote my original post, my brain must need defragmenting.
My code goes as follows
degrees = 0 to 360 in 10 degree steps
real(mode shape) * cos(degrees) + imag(mode shape)*sin(degrees)
Many thanks
Harry
If you want to get the magnitude from Re and Im data, you need to take the square root of the sum of the squares of the magnitudes.
... and the phase is arctan(Im/Re).
