LINE OR LINES INSERTION AND COPY
sorry to be asking so many questions. but have been perusing through to find something that can help, but can't find it or i don't know what I am looking at.
Anyway, my question is.
if I have typed a 1,2,3... and so on, in column A on sheet 2, rows 2, 9, 13( now each can be different each time e.g. 4,5,21,35)
Can a macro be created that will look at sheet 2 and copy (say) Cell D5 on sheet 2 (since Column A has been marked),then go to sheet 1 insert row(s) under a certain heading ( this is my main form )where it needs to be placed and place what was in D5( sheet 2) into cell (say) B4 on sheet 1 ( or what ever row it needs to be)?
RE: LINE OR LINES INSERTION AND COPY
Sheet 1
Column B
Row 1 5410-6020(0)M-4719-F
Row 2 5410-6020(2)H-5030-R
Row 3 5003-5410-6015
Row 4 7503-310p-6620
Sheet 2
Column A Column D
Row 4 1 123594
Row 9 2 556978
Row 21 1 24891006
Sheet 3
Column A Column D
Row 11 1 123594
Row 12 2 556978
Row 16 1 24891006
So From Sheet 3 Row 12 Column D put in Sheet 1 under Row 1
From Sheet 2 Row 9 Column D put in Sheet 1 under Row 1
From Sheet 2 Row 21 Column D put in Sheet 1 under Row 3
From Sheet 2 Row 4 Column D put in Sheet 1 under Row 2
and so on.
At the bottom you see Sheet 3 Row 12 Column D, So what I am trying to explain ( terribly at that ) is that when I Click a "command button" (failed to mention that)that it looks through all worksheets.... notes a numerical number in column A in all worksheets... then goes across the rows to column D grabs that cell and copies it to worksheet 1 under column B, but needs to insert a row prior to pasting. And also need to be put under the proper heading.... Again sorry, if I could paste an exact picture, I think it would be of more help explaining what I am trying to do.
See FAQ559-1100: How Can I Show An Image In A Post and FAQ559-1177: How Do I Make Files Available For Download? ... No Emails Required
Are you saying that it can only be done, if the headings were attached in each worksheet? Which means i would have to manually enter this each time... if this is true, then I suppose i need to check other options.. or just forget this whole idea of automation....
e.g.
Sheet 2
Column A Column D
Row 4 1 123594 5410-6020(0)M-4719-F
Row 9 2 556978 5410-6020(2)H-5030-R Row 21 1 24891006 7503-310p-6620
Start here http
and come back with your more specific and focussed questions when you have a good grasp of the basics.
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376: Eng-Tips.com Forum Policies before posting
Steam Engine enthusiasts
Steam Engine Prints
TTFN
