SSMA vs Dietrich vs Sigma Stud
I'm looking at designing a multistory lightgage structure. Most of the lightgage I've done before was single story using standard studs. I had a heck of a time getting strap bracing installed correctly. With multistory, I dont want to be dealing with the same problems.
Have any of you used The Steel Network (sigma studs)? It looks like they have a proprietary system that would go together much better. Do they do any of the design? Just not sure about the process or if there's really any benefit to using them.
Any words of wisdom are welcome.
RE: SSMA vs Dietrich vs Sigma Stud
Can you use sheathing (GWB or OSB) instead of using straps?
DaveAtkins
SigmaStud is stronger and more efficient. This building is 5 stories of lightgage tall.
Dont you think the details of their strap connections are much cleaner than field cutting gussets, field welding etc?
