Hexagonal Callout on Drawing
Hello All -
First time post... I need to call out a hexagonal shaft on a drawing, but I'm not sure if there is a specific way to call it out (i.e. flat to flat, Ø of hex, etc.)
Any and all help is Appreciated.
Best Regards,
Victor
Best Regards,
Victor
Mechanical Engineer/Consultant
Medical Devices
"When I am working on a problem, I do not think of beauty, but when I've finished, if the solution is not beautiful, I know it is wrong."
- R. Buckminster Fuller
RE: Hexagonal Callout on Drawing
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
I've also seen dimension across flats with HEX after it like ewh.
Rarely if ever have I seen it dimensioned to the corners or the equivalent diameter.
Interestingly I don't see a single example of a hex or other regular polygon in ASME Y14.5M, I only looked briefly though.
KENAT, probably the least qualified checker you'll ever meet...
MIL-DTL-1222J STUDS, BOLTS, SCREWS AND NUTS FOR APPLICATIONS WHERE A HIGH DEGREE OF RELIABILITY IS REQUIRED; GENERAL SPECIFICATION FOR
available at ASSIST:
http://assist.daps.dla.mil/quicksearch/
This is standard in industry.
Cory
