Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Congratulations on a brilliant idea and a great site..."
Geography
jfoe (Petroleum)
26 Sep 07 9:12
I am trying to clarify if performing a calculation for t-min. on a vessel, when inputing the pressure(P), would you use the MAWP/design from the dataplate or U-1 form only, or would you add the static head to the MAWP.
Question 2: After performing t-min calcs, would you add the corrosion allowance to the result or just use the calculated t-min by itself.( I was taught to add the corrosion allowance to the Radius in the calculation and was wondering if this was the same as adding at the end or not)
Question 3: Like in the first question but now calculating for MAWP, would you add the static head to the result?
I have heard different opinions on these questions and I want to be sure to use the correct way of doing things.
Close Box
Join Eng-Tips® Today!
Join Us             Close
