Anyone use markups within ACAD 2006
Hi!
We currently use paper checklist and red pen method to mark up drawings.
Does anyone use the markup system within ACAD? If so reflections, limitations, learing points, implimentation advice...
All greatfully recieved
Scott
RE: Anyone use markups within ACAD 2006
I don't use it because I'm the only person in the office who can use AutoCAD and also the only person with it installed. It is a limitation that the person reviewing the drawing would have to be proficient with AutoCAD to use it. I could see how it would be a benefit if collaborating with people in other offices as 24x36 drawings are difficult to scan and email. If I were reviewing a drawing electronically, I'd be much more likely to fix the issues than to mark them up as it would probably take just as long. That is how I became a CAD user in the first place.
Thanks Francesca.
I was worried that it might be a bit cumbersome.
Although we are currently reviewing drawigs in office between CAD users there is occasional scope for work between remote offices or subcontractors.
The whole argument about doing the changes can save time in the imediate sense but then if the creator never has the error highlighted then there is greater chance of it reoccurring.
A lot of the my clients don't have or use AutoCAD so what I do is create a .pdf file and e-mail it to them.  They can make comments on the .pdf using Adobe Acrobat and e-mail it back.  I can have AutoCAD and Adobe open at the same time (ALT TAB) back and fourth between the programs or just print out their comments and work from the print.
If you don't want to do either of those, you can also use the SNAPSHOT tool in Adobe Reader and select the page or area with comments.  Then paste it into your AutoCAD like an image using (CTRL V).  After you have made your edits, just delete the image from the .pdf file that you inserted.
Your client or reviewer doesn't have to open AutoCAD or even have access to it.
I haven't used the Markup or RMLIN options.  We actually create a layer called _Design with a color of 142 (red) and make it a non-print layer.  Anyone who uses AutoCAD and reviews can give instructions on this layer, but we mostly use it to document our design information in the drawing so 3 months from now when some one asked why you design it a certain way, your backup is right in your cad file.
I hope you find these ideas useful.
