Shifting of phase angle
At one of the power station, during insitu balancing, after putting trial weight, the phase angle in the horizontal direction moved into clockwise direction and the phase angle in the vertical direction moved into anticlockwise direction. We want to know the following:-
1. Whether it can be said that balancing will not help in above case.
2. What will be the reason for such behaviour
Kindly give your valuable feedback.
(steam turbine)
(steam turbine)
RE: Shifting of phase angle
Cheers
Greg Locock
