USGS Hazards by lat/long
For some time I've been using the USGS Hazards website to look up my S1 and Ss values for building design under the IBC 2000, 2003, etc.
I now key in the same website (http:// eqint.cr.u sgs.gov/eq -men/html/ lookup-200 2-interp-0 6.html)and get this:
It appears that they are distinguishing between their values of short and 1 second parameters and what the IBC maps use. In my area, the values are the same but they imply that there are some areas where the values are different.
Anyone know WHERE the values differ?
Quote:
Problem Loading Page
In addition to technical difficulties, there are two other reasons that we have decided to discontinue this online appilcation:
Hazard values by lat/lon and zip code, from both the 2002 and 1996 USGS National Seismic Hazard Maps, are otherwise available via the downloadable USGS Java Ground Motion Parameter Calculator -- please see http://eart hquake.usg s.gov/rese arch/hazma ps/design/. We continue to work on making this downloadable application as easy to use as the online application.
While the online application has been down, it has come to our attention that it was being used by some to obtain ground motion values for building design. For some locations in the U.S., however, the design values in modern building codes (e.g., the International Building Code) are significantly different than the USGS hazard values, sometimes by more than a factor of two. Fortunately the hazard values are never smaller than the design values -- i.e., the hazard values are always conservative. The new downloadable application more clearly differentiates design and hazard values.
RE: USGS Hazards by lat/long
by the way, be sure to keep up to date with the new maps coming out. if you look at the preliminary maps available, there are a couple maps that show the difference from the current maps to the new maps. some areas will see another round of lowered values similar to that from the '96 to '02 maps.
http:
here's the particular paragraph:
The seismic design loads in the International Building Code (IBC) are based on the site-specific hazard analysis carried out by the California Geological Survey (CGS) and the U.S. Geological Survey (USGS). The 475- year return-period site-specific hazard analysis did not capture the effects of rare but large earthquakes, which pose significant aggregate risk in the New Madrid seismic zone, the Pacific Northwest, and the Wasatch region. Therefore, the Building Seismic Safety Council decided to increase the return period of the ground motions in the IBC to 2,475 years but require the design of buildings for only two-thirds of the 2,475-year return-period ground motions. The two-thirds of the 2,475-year return-period ground motions were “too high” in the western United States due to the high occurrence rate of earthquakes. Therefore, the 2,475-year return-period ground motions were truncated by the “deterministic limit” to obtain the MCE (maximum considered earthquake) ground motions. As a result of these arbitrary adjustments and truncations, the seismic design according to the IBC is difficult to articulate.
And what did the USGS think it was being used for? Come on. This is a no brainer.
Mike McCann
McCann Engineering
again, i have not found the specific locations that the ibc usgs maps differ from the usgs maps. but this was the concensus among a few seismic people i talked with. i'm sure usgs would prefer their original maps be used since they are based on scientific data and not political motivation.
Mike McCann
McCann Engineering
i checked a few spots along the new madrid but couldn't find a variance. however i was just using zip code searches. maybe it's at very specific locations or something. i'd be interested to see where the differences are and the magnitude of the differences.
http:/
http:/
here are the actual proposed maps.
h
h
http://gldims.cr.usgs.gov/nshmp2007/
h
in particular see "topic 5a notes" (around slide 75-80).
