Piping practices
Piping practices
Piping practices
I am designing both air and natural gas pipe manifolds. What is the proper piping practice with regards to sizing the manifold for the number of branches of pipe.
Example: (5) 1.5" natural gas lines would require what size manifold?
Any help is appreciated.
RE: Piping practices
Without checking flow and pressure drops at various locations along the manifold and all that, I think you can get a reasonable first size by setting the header diameter to that required to give an internal cross-sectional area equal to the sum of the branch internal areas.
http://virtualpipeline.spaces.msn.com
I would probably also add about 40% extra capacity to BigInch's figures for future tie-ins.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
