stretching a compression spring
I am a computer engineer not a mechanical engineer so my question is pretty basic.
What effect does strechiing a compression spring beyond it's limit has on it's rate. For example if I have a spring that is has a 2 inches free length with a rate of 8 lbs and I stretch it to so it that it's free length is 4 inches what would the rate of the spring be?
RE: stretching a compression spring
The spring rate would increase if you stretched the spring so that its mean diameter suffered a permanent reduction,
however you would also have issues with bending stresses
in the wire if the pitch angle of the coils is greater than 15 degrees.
If you can tell us what you are trying to do we might be able to help you further.
regards
desertfox
The stiffness of a spring is given by the formula:-
k = G*d^4/(8*D^3*Na)
where G = modulus of rigidity
d = wire dia
D = mean diameter of spring
Na = number of active turns
If you permanently stretch the spring you will reduce the mean diameter of the spring which in the formula is raised the the cubed this will increase the spring rate.
regards
desertfox
Sencond problem is that if the spring was correctly designed it was designed such that the stress at solid highet will be less than the yield or the ultimate torsion stress. Now that the spring can deflect more than it was designed to the spring will see much higher streses than allowed when you compress it all the way.
http://israelkk.googlepages.com/home
Current extension spring has the following characteristic:
Spring 3.41" = 5 lbs
5" = 11 lbs
Rate = 4lbs
I am making the modification as add on/replacement parts only with no alteration to the rifle so I have some constraints.
To add a compression spring the spring will have to ride on a rod and into a hole. The total length of the cylinder is 2” and the rod is 1.6 inches with the spring on the rod and in the cylinder and the rod overlaps the cylinder by about .2”.
The total movement of the system is only 1.59 inches. I need to add a hole (in an attached bolt weight) and I like to make the hole as small (<=.25”) as possible so to reduce amount of weight I had to add to another part of the system.
I tried to find a stock spring but cannot find one long enough and the price for a custom one is far more than I am willing to pay.
So I need a compression spring about .25” and long enough to start with an initial load of 5 pounds and will end up at 11 pounds at 1.59 inches.
Is there a way to contact the rifle maker?
Springs, as we well know, are well analyzed and understood. Too often, I feel, we tend give the complex answer to a simple question. You are, of course, correct; if the wire has a fixed length and you stretch the spring, clearly the diameter changes and the spring rate changes. But it is a secondary effect that I feel clouds the first order, basic understanding of how springs work.
Generally the recoil springs used on rifles are made using standard music wire. They tend to last about 10,000 cycles. They do not fail so to speak but will weaken and cause feeding or ejection problems that call for a replacement. (The extension spring is much more dangeous if the spring breaks) Most recoil springs on semi-auto's are contained inside a cylinder or ride on a rod. In my case I am going to do both. It should be pretty straight forward since the resulting system will have the same characteristics of the original system..
Because the extract/eject/feed/insert cycle normally happens too fast for the human eye to see, the dynamics of the springs are at least as important as the static numbers.
In the case of recoil- powered mechanisms, as I think this one is, the kinetics of the entire system are important to its function, e.g., you may have to change the recoil springs to deal with a slightly different cartridge.
The springs are subject to shock, and to surge, and to abrasion from the guiding tubes or rods and the particles that are generated by powder combustion. When the springs' dynamics change even slightly, the gun fails to cycle properly, which limits its utility and greatly annoys the owner. No one would intentionally underdesign a product sold to an irritated gun owner. Not twice, anyway.
Mike Halloran
Pembroke Pines, FL, USA
Bullpuppy's question was what happens to the rate of the spring if he stretches it and not how the spring works.
Secondly now we know what the application is regarding a gun recoil mechanism I am glad he didn't just stretch the spring on your advice as it might well have let him down with serious consequences.
desertfox
a) the force of the hammer on the bolt when fired
b) the weight of the bolt
c) the recoil spring force
These all have to be correct to prevent case rupture and to allow proper cycling. Too much force will prevent the rifle from cycling. Too little force will cause case failure. Of the three the force of the hammer spring and the weight of the bolt contribute the most with the recoil spring mostly controling the cycle time.
From what I am getting from this is that a shorter spring is better. In this system the spring fully compressed must not be more than 1.8 inches. So I should try to design find a spring on minimum length to satify the requirements.
I agree with israelkk on this your spring needs to be designed for fatigue and just buying one of the shelf and or
modifying an existing spring would not be suitable.
regards
desertfox
It is best to use a qualified designer that has a broad understanding of the system requirements in combination with a respected manufacturer to make sure that the designed spring can be manufactured.
But yes, I do agree with you. There are many companies out there that do not understand the design side of things. But if you stick to the big players in the spring industry, they tend to have a good design staff.
The characteristics
Lenght = 11"
OD = .240
WD = .028
Rate = .77 lbs
Load = 4.56
Active Coils = 121
So I read somewhere that if you reduce the number of active coils by 50% then you double the rate. Is this true?
If that is the case then I need to determine at what length would the spring have a rate of 4 lbs and see if that will work within my constraints. What would the formula be to determine that?
Outer Wire Free Part Total E-mail sales@springsfast.com
Dia. Dia. Length No. Rate Load Coils Ends Material Finish Web www.springsfast.com
(in.) (in.) (in.) (lbs / in) (lbs)
0.240 0.028 11.000 661 0.77 4.56 121.0 O M N
Yes if you half the number of active coils you double the rate, however you will also probably overstress the spring so that it takes a permanent set the first time you compress
it to the length you want and more importantly the force you think you have at an intial compressed length will actually be less due to the spring taking a permanent set
(spring wire exceeded its yield stress).
My advice don't modify a spring, in addition for your application you need the spring ends squared and ground so that the spring seats squarely between the two metal faces
this again is unlikely to be achieved by modifying one.
regards
desertfox
http://www.centuryspring.com/
Bullpuppy"s original post sounded theoretical. I never suggested he actually stretch a spring (although who of us havent done this to a hardware store spring).
Just for fun, I looked at how the diameter of a spring would change if you stretched it to double it's length. I used 5 turns, one inch diameter, 5 degree helix angle stretched to a helix angle of 10 degrees. I calculated a diameter reduction of about 1% creating a spring rate increase of about 3%.
Nick
I love materials science!
I agree with your calculation for a spring with a 1" dia and helix at 5 going to 10 degrees.
I did a similar calculation using 1" dia (mean dia) but used
10 turns with a wire dia of 0.1" then I stretched it from a 2" length to a 4" length in accordance with the original post (in terms of length anyway) the result was for the 2"
spring the rate was 14.375lb/in and reducing the mean dia for the 4" length gave a spring rate of 17.3lb/in thats an increase in rate of just over 20% in my book thats a significant increase. Now consider if you compress this spring by a given amount the shear stress in the wire increases by 20% again not an insignificant amount.
Anyway its acadamic now.
regards
desertfox
You do not need a seperating washer to keep them from falling inside them selves... In fact that is a bad idea, I deal with customers ocassionaly who try that, and all they do is end up spacing it to much and causing failures. If they are the same size, they will not "fall" inside of eachother, they will but against eachother just fine.
