fault in a generator of a ship
We got 4 diesel units (1000 kw)in a ship, and in the moment of the fault we got one of the generator coupled to the main bars, in island mode.... the voltage of the generator start to swing, at this moment the crew of the ship see it and couple the other generator... after conect the incoming generator, the other generator is disconected for overcurrent trip, the trip is at 1,3 full load current.
When I see the generator i find the next: AVR with the rectifier diodes in short circuit, Permanent Magnet generator totally burned, and a diode positive of the rotor is shortcircuit.
The load in the fault moment was 300 kw.
RE: fault in a generator of a ship
May be, you can share with the forum the findings once the generator is open for inspection.
Thanks.
respectfully
Keith Cress
