Hole Wizard files
Hole Wizard files
Hole Wizard files
Hi all....Gloomy here is Midwest...love gloomy days..
Issue: updating Hole Wizard files...
is there any way possibal to actually EDIT a Hole Wizard file?
Thanks in advance
Rip
SolidWorks 2007
SP 4.0
RE: Hole Wizard files
If you're asking weather or not you can edit the master file, the answer is always "Yes..but I wouldn't recommend it."  You can copy/create your own standard within the Hole Wizard and edit away, though.
Dan
www.eltronresearch.com
