show removed material?
I'm detailing a part to be made from a commercial sprocket. The model shows it in modified form, with most of the hub parted or faced off. I want to show and dimension the material that _used_to_be_there_ to give the bidder a fair picture of how much metal must be removed.
The way I'd do it on paper is a couple of phantom line rectangles in a section view, a reference dimension, and a flag 'remove', or something like that.
What is the SW way?
What is the SW way?
Mike Halloran
Pembroke Pines, FL, USA
RE: show removed material?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
Pete
I put a sketch on the drawing view. So far so good.
Mike Halloran
http://www.EsoxRepublic.com-SolidWorks API VB programming help
If a part is created from another (blank or purchased part), I would insert that as a base part and remove material as required.
