NFPA #13 Swivel Hanger
A building has structural members, W's and bar joists, that run with the slope of the roof on pitches between 2 in 12 to 6 in 12.
I need a swivel type (if it is made) beam clamp assembly so the rod can hang straight down.  Bending of any rod not allowed.
Does anyone make such an attachment?
RE: NFPA #13 Swivel Hanger
Have you tried Lindapter.  Do a google search.  It may be Lindapter.com.  They offer a swivel type hanger that is good for around 20°, it may even be up to 45° by now.  I know it will actually swivel that far, but I am not sure of the listing.
NFPA allows for bending of machine threaded rod if that would become a possibility.  I realize you aren't to bend ATR.
I think that Sammy also makes a swivel type hanger.  I am not sure if it would be applicable on your project.
Good luck!
Travis
Thanks Travis,
I am thinking of using a flat faced beam clamp with 3/8"x2" machine bold with angle clip and from side of angle clip using eye rod and short 3/8"x1" machine bolt, washer and nut to obtain swivel.
SD2:
That should work, but if it goes outside of the "standard" hangers as shown in NFPA 13, you may need to have a structural PE sign off on the hangers.
T
trying to start a new topic, is it this city computer or is it the web site???
I think it was the web site.
"do not know anything about this product"
Interesting product but don't see a UL or FM stamp.
