Enthalpy of Solution vs Temperature
I am looking for a simple way to describe the dependence between the enthalpy of solution (e.g carbon dioxide (g) in hot water) and temperature.
Thanks in advance,
Mike
Thanks in advance,
Mike
RE: Enthalpy of Solution vs Temperature
Thank you very much.
P.S. What is the sytemabsortion?
Mike
The temperature dependence of the solubility of gases is given by the relation
where c is the number of moles of gas dissolved in a definite volume of solvent and ΔHsol is the molar heat of solution, assumed constant in the given temperature interval.
Since values of c as function of T are amply tabulated, one could solve for the molar heat of solution from:
2.303R can be replaced by 4.576, and T are in Kelvin.
